跳转到主内容
Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix. Model number: ME370T.
150 个问题 查看全部
Any guides on changing the Charging Port?
I am pretty sure my charging port is screwed up as well as needing a battery replacement. You have a good battery replacement guide will you put up one for the charging port too please?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
You will need to replace the I/O cable assemble as it contains the micro USB socket used for charging - the link for the I/O replacement guide for the original nexus 7 can be found below
Nexus 7 I/O Assembly Cable Replacement
这个答案有帮助吗?
得分 1
1条评论:
Aah thank you, i didnt see that. Much appreciated. :)
完成的
添加一条评论
I didn't realize I could do it myself, I thought I'd have to take it to a repair shop. Actually this will save me money.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rayn 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 522
