跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
问题已关闭
Shutdown immediately during boot [1s], but can boot into DFU mode
Hello everyone,
I have received a broken iPhone 4S from my friend, and I would like to ask for some advices from experts here :)
Symptom:
- Press power button -> boot up -> shows Apple logo -> shutdown (whole situation happens in 1 second)
- Plug into my iMac -> boot up -> shows Apple logo -> shutdown -> boot up -> shows Apple logo -> .... (looping the above case, with the same speed of shutting down)
- Boot into DFU mode, stable running! Plug in to iTunes and try to do a restore -> dead again when iTunes is attempting to reboot the device to do the restore (I guess it left the DFU mode in this stage?)
Does anyone has ideas what's wrong with the device?
Much appreciated for any suggestions, thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
All these symptoms point to a defective battery replacing should sort your problem
这个答案有帮助吗?
得分 0
2条评论:
Tested, unfortunately it is not a battery problem...
完成的
Download tiny umbrella and exit recovery mode
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 86
