跳转到主内容
加入维修社区 - 创建账户
型号 A1213或A1218,闪存容量:8、16及32GB
iPod touch has no backlight
I have tried multiple lcds and all have the same problem where the backlight will not turn on. the same lcds work perfect on a different logic board. this logic board has water damage but works fine except it will not make the backlight work. what part on the board needs replaced? anyone have a schematic?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
What iPod touch generation do you have ?
完成的
I have been working on the 1st generation 8gb and 16gb models so far. this one with the backlight problem is a 8gb
完成的
添加一条评论
4个答案
已选择的解决方案
since some iPhones have the same problem, i would say that a coil is fried.
i found a picture on a gsm forum and the number 2 should be responsible for your problem.
some a replacing the fried part with parts from nokia bb5 series or SonyEricsson phones
这个答案有帮助吗?
得分 3
13条评论:
Hey thanks i think i will try that one then. im new to this tech stuff i am trying to train myself. i have some extra logic boards laying around i will attempt to solder in that piece. i have another one that works perfect now except the wifi doesn't work. can you switch out that top portion above the ribbon where the antenna is or are you just stuck at that point?
完成的
it's not easy to change the coil - no real chance with a soldering iron - i use a hot air rework station for those parts and even than it's not easy. is the wifi totally dead? don't ever think to change the communications part ;-)
完成的
when you turn on the unit in the settings it just says "no wifi"
well i wanted to attempt the coil but i don't know what to do now, i can't find any video on youtube about the change either.
完成的
ok i watched the air rework station and it looks like something i can do. how do you reinstall the coil? is it a solder?
完成的
The problem are the "glued" parts - this is whay those kind of repairs are not easy. soldering with hot air or infrared light are some times the only way to fix something, but there are many ways you could fry the logicboard
完成的
显示更多的8条评论
添加一条评论
Sorry to bump a year old thread but the topics contained are relevant to my needs. I also have an Ipod touch 1st gen having the same issue, I have replaced the battery, the lcd, and the transformer highlighted in this tutorial however I am still having the same issue. There are no signs of water damage, or any destroyed components. Are there any I/O management ICs or controller chips I should try replacing? Any additional assistance would be much appreciated.
这个答案有帮助吗?
得分 0
添加一条评论
http://img686.imageshack.us/img686/9351/...
I found this coil to be the problem when I replaced the battery.
这个答案有帮助吗?
得分 0
添加一条评论
hi
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
chad franklin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 28
总计 11,814
