跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
问题已关闭
Battery drains very fast after screen replacement
Hi everyone,
Just to start I repair lots of screens for all types of devices so I have some experience in this area. Maybe 200 screen changes and I've not had this problem before.
I changed a particular screen for an iPhone 5 white. It went very smoothly but a week or 2 later the individual came back to me and said the battery drains really fast, in 20 minutes from a full charge. He was just enquiring if it was the screen source this!
Any help would be much appreciated!
Thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
Did I remove the battery connector when changing screen I ask this cause there are small componants below it that might have gotten knocked off..
If not then it could be a simple case of a new battery iphone 5 is horrible for battery's
这个答案有帮助吗?
得分 0
2条评论:
No I didn't go near the battery. This was why I was so confused since the battery and it's connector are shielded
完成的
I would try a new battery I could be that it decided just to go faulty hopefully a new 1 will sort it out
完成的
添加一条评论
I wouldn't rule out that the new screen is causing a short on the Logic board, I have seen this many times, when the phone is powered up does it get warm to touch ? That would tell you it has a short.
这个答案有帮助吗?
得分 0
1条评论:
My Iphone 5 does this, how would I go about fixing it?
完成的
添加一条评论
I changed my iPhone 5S screen, then the battery life went to 5-6 hours while stand by.
I surprise and I thought the new battery is needed. Before buying new battery, I check what if the new screen is the problem. I changed my screen with my wife original screen, but problem got worse. Now both iPhone 5S's batteries drain faster and Touch ID's do NOT work on both phone.
I thought my phone battery drains faster because of new screen or battery. What about my wife's iPhone 5s. Everything is original and I placed everything back to phone. Now battery drains faster and both phone Touch ID's do NOT work. I believe new IOS has some future that when you open the phone, somehow some functions starts failing.
这个答案有帮助吗?
得分 0
添加一条评论
I'm having the same issues. Replaced my iphone 5s screen and now my battery drops exponentially. Sometimes it will erradically change percentage and eventually shut off. If i view snapchats or am on skype i will go from 100% to 70 within about 30 seconds and jump to 40% and so on then when I plug it into the charger it goes back up to 100% or 80% but its always a drastic jump. sometimes it will leak 4% every couple of seconds and so on. IF anyone has any information regarding this problem please send me an email yepitsteddy@gmail.com
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 12,372
