What is the F26 code?
Washer turns on and starts to add water and then clicks off. The timer works and eventually the F26 starts flashing.
Thank you!
It is a door switch error code, either the connecting wires are loose or the switch is defective. The door switch error code will also be seen if the door is not closed completely. Look fro loose wires first.
这个答案有帮助吗?
The wires were fine so we are going to replace the door switch. Thanks so very much!
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 5,357
what is the f 06 code stand for?rlonadier@windstream.net
由 bob 完成的
I have a load in the machine and get start there error code F26. How can fix the problem
由 Kam 完成的
