跳转到主内容
iMac 是 Apple 的一体机台式电脑产品线。
8382 个问题 查看全部
Replacing my LCD screen on iMac g5
My LCD screen on my iMac g5 is going out. Half my screen is black/grey/blue and half is showing normal pixels. Everything is running normal with the hard drive. When i turn it on only half of my desktop icons appear. Question...Can my LCD screen be replaced or can i connect a 2nd monitor to CPU/Hard drive?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
please confirm the model. use the id your mac: http://www.ifixit.com/info/ID-your-Mac/
完成的
Yes, please clarify how many inches or the model number if you can.
完成的
添加一条评论
1个答案
已选择的解决方案
Could also be a bad LVDS cable. Try to connect to an external monitor to confirm that the graphic chip is fine. Changing the screen is not that difficult, only the front bezel catches can be a bit of a pain.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
lamont 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 8,535
