跳转到主内容
PS3是索尼电脑娱乐推出的第三代家用电脑娱乐主机。2006年11月11日发布,取代上一代产品PS2。
Shutdown automatically and red light blink
I've got PS3 Fat 80GB in 2010 or 2011 old version. I didn't use it much. It suddenly shutdown when I play "Midnight club Los Angles". Only in when loading. It happens few times when I start game immediately. I noticed that It when I spend few seconds in game menu and start game, it doesn't shutdown. And few months later, it happens alot. Now I've got NFS Run and I can't run it. GTA4 and COD BO2. Non of these can be played. IT always shutdown. I've tried so much to pass it by spending some times. But now it restart at first 10 or 30 seconds in PS3 normal menu.
It beep ones, yellow light, double beep with red light and blink it. When I start it again, ask me to recover and all going fine. And repeat.
I'm from Sri Lanka and little bit hard to contact Sony for repair. Hope this may help me.
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
1个答案
最有帮助的答案
Hi,
You have a problem with overheating. Open and clean the system and change the thermal paste. And be sure the place of the game console is good for ventilation.
If this not help you, you can try YLOD fix kit.
Regards.
这个答案有帮助吗?
得分 3
5条评论:
Hi there,
Thank you for your reply. It has more space. I don't know much about it to clean. How can I do it? Open it and clean by small brush or something or should I have to use any chemical?
And it don't work so much time to get heat. It work only take about 5 or 10 seconds from start. Anyway I'll watch that video. Thank you.
If you have any idea about it. Please let me know.
Thank you.
完成的
Yes, it's good to find and watch video how to do this. I'm not sure where exactly is the problem. But this is first and more easy step, clean the system inside, change the thermal paste and check the fan system. The thermo sensor is under the CPU. If the thermal paste is too old or you fan is not working this is a reason for the system to shut down for prevent overheating.
完成的
I bought it from Singapore in 2010. I hear fans are working properly. I'll do it and replay. :)
完成的
Hope you guys will see this again. I tried it. It doesn't work. As I FIX IT said, I've bought new thermal paste and done everything. Still have that issue. I have no idea what to do now.
完成的
Try CPU reballing.
完成的
添加一条评论
添加你的答案
Umesh Gallage 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 5,656
