跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
Home button is stuck and will not press down to work!
I have the same problem but it's with a iPod 4th Generation. Can that be fixed? Like, I don't want to open it apart or else I might wreck it. Are there any other way? I am currently using the Assistive Touch but I want to use the home button! I heard that if you use the A.T, your device gets more "laggier". So please anyone help me ASAP!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
There are no quick permanent fixes. If your leery about working on your device, an iPhone/iPod tech can pop open the screen and check the power button assembly and replace it, and/or the power flex cable (on the iPod 4th if the flex cable needs to be replaced it requires soldering).
这个答案有帮助吗?
得分 2
添加一条评论
Hello the home button does not require soldering it's easily replaced only problem would be opening it as it's glued down and needs heated up and pryed off..
I would get a shop to do it as you don't want to risk breaking the screen aswel
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Akhan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 125
