跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
screen became a bar code
i went on a walk in the texas heat but it only reached up to around 70-75 degrees and then as i git home i pulled out my phone, that was placed in my back pocket, and i noticed my screen had turned this redish to grey screen that had vertical lines going down the screen making it look like a barcode. Help please i really dont know what to do
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
and the screen works prefectly fine i have a video of it you can see a little part of the working screen please someone help
完成的
添加一条评论
1个答案
已选择的解决方案
In the back pocket you may have damaged the lcd. I would try a Home+Power to reset the phone. If that doesn't work, you can try powering down, lifting the glass and re-seating the cable connections. Also, from what you stated, it is plausible that when you sat down there could have been a coke can, or anything behind you that could have spilled into the phone and dried out without you even noticing (but, in that case I would suspect many more issues popping up).
If none of the above works, order a new screen and give it a try. But, honestly, when I typically see a white screen AND banding, and reseating the cables doesn't work, 99% of the time it's a faulty lcd (or in the case of replacing the screen a cable accidentally gets crimped/damaged). :(
这个答案有帮助吗?
得分 2
1条评论:
Same problem I'm going for a screen replacement
完成的
添加一条评论
添加你的答案
Alyssa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 5,314
