跳转到主内容
Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
408 个问题 查看全部
问题已关闭
iPad won't charge from 10w charger but will from computer.
Hi i Have an iPad 4 wi-fi + Cellular.
This is a really weird issue the iPad when plugged into the Apple 10w charger & lightning cable that came with the iPad comes up with not charging.
I have tried several different chargers lightning cables all with same result i have also replaced the lightning port & even changed the battery.
It will power on the iPad when it is switched off so it knows a charging lead has been connected.
It is recognised when i plug it into iTunes I can sync ETC & i have reset & activated the iPad through iTunes via DFU too.
Strangely when connected to my Mac it shows the charging icon where normally an iPad would show not charging when connected to a computer.
Apparently it will also charge ok from a 5w iPhone wall charger.
I did purchase the iPad in this condition with the intention of refurbing & repairing the issue.
Its like the charging has flipped in reverse
Its got me stumped any ideas or help greatly appreciated.
Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Is it actually not charging, or just saying that it is not charging?
I had an iPad mini like this once---I tried a few different dock connectors and what I remember is that it would say 'not charging' but it would actually charge up just fine.
这个答案有帮助吗?
得分 1
3条评论:
Hi Jessa
Thanks for replying.
No its not charging the % does not go up but it doesn't go down either when you use it.
What is weird is when connected to a computer they normally say not charging but this has been reversed it shows the little lightning icon next to the battery icon indicating its charging i shall leave it a while to see if it does actually charge it.
What is mad is i have just plugged it into an iPhone 5W charger & it has now come up with the lightning icon next to the battery & says its charging ????
完成的
Does the low battery logic engage when charge falls below 5%?
完成的
Not Sure battery is still up over 20% at the moment.
Will let you know when it gets down to 5%
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 500
