跳转到主内容
Improved second generation Google-branded tablet with a 7" screen.
98 个问题 查看全部
Can I upgrade my storage?
Is it possible to upgrade my 16GB 2013 Nexus 7 storage to a 32 GB or more? Sadly the operating system takes up more storage space than I expected (a whole four gigs!) so now I only have 112 gigs of usable space, and I need a little more for what I use my tablet for. Any help at all would be appreciated, thank you in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
最有帮助的答案
Hi,
You can't do this. No way to change or upgrade internal memory. This memory (i.c. chips) are soldered to the mother board.
Regards.
这个答案有帮助吗?
得分 3
添加一条评论
the other option is to see if you can buy the motherboard on ebay with 32 or 64GB and swap out your current with the new motherboard containing more space
这个答案有帮助吗?
得分 1
添加一条评论
You can't add more internal storage, but you could add some external storage. There are new flash drives that plug into the micro-usb port and also plug into a PC's usb port (but only one at a time.) They're called USB-OTG (On The Go) drives.
这个答案有帮助吗?
得分 0
1条评论:
How does that work? Just a cable to connect to computer and then use tablet while connected.or is there a drive also that is portable?
完成的
添加一条评论
Yes its possible. Just go to settings, internal storage and click upgrade storage to 32 gb, 64gb or 128gb.
这个答案有帮助吗?
得分 0
1条评论:
Hi Abraham,
Were you thinking of another model perhaps?
I have the Nexus 7 2nd Generation and unfortunately you can't upgrade its storage.
完成的
添加一条评论
添加你的答案
Jacob 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 11,875
