跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
问题已关闭
iPhone 5 with faulty logic board, repair?
Hello.
After many days\ weeks \ month with testing I have concluded that I have a faulty logic board on one of my Iphone 5. I have tested the logic board in different phones and the problem continues.
The Logic boards seems to work OK. But the battery discharges after 3-4 hours and after that its dead.
Then i have to take out the battery, charge it for some minutes in another Iphone 5. Put it back again, and then it works again, charges up to 100%, but discharges after 3-4 hours.
Is there any way to fix this? Or is no point? I have cleaned the logic board with isopropanol, and there is NO water damage to the board.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
This is almost certainly a failure of the U2 chip on the board. There was once someone on here who said he could do it. It may help to guide you to google "iPhone 5 U2 replacement service" or something like that.
这个答案有帮助吗?
得分 0
添加一条评论
The logic board has leak current problem. Try restore to the latest software to rule out software issues. If nothing changes, check all functions like camera or audio. Also plug it onto a Mac with Xcode to check device logs. You may be able to narrow down the faulty hardware like camera or audio chip not responding.
If everything seems to be working, then this repair is going to be difficult because it is very difficult to identify a broken component if everything seems to be working. Try starting with U2 as jessa suggested. U2 is the USB interface chip if I remember correctly.
If you replace the U2 chip and the phone works, blame Bono for the fault.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 4,071
