Does the 2014 MBA use the same display as the 2013 MBA
My understanding is the 2014 MBA was really just a .1 processor speed bump and an updated OS. Are the internal parts swap able? Is the 2014 MBA display the same as the 2013 MBA display?
The display assembly for the 11-inch Mid 2013 and Early 2014 MacBook Airs share the same part number. Aside from the logic boards the internal parts for these two models are the same and/or are interchangeable. I have not had the opportunity to check the part numbers between the 13-inch Mid 2013 and Early 2014 models yet, but I expect to find the same result.
这个答案有帮助吗?
According to this site they are not the same. '10's through 12's swap... the 13's and up are not listed as being compatible.
If you find out different please come back and correct me.
One sure fire way to find out is to get the Manufacturer's part umber off the back of the display and see what it reads you can then search for compatible/comparable part numbers.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 320
