跳转到主内容
加入维修社区 - 创建账户
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
Bottom screws won't come out, just spin in place.
After replacing the battery and back cover on my iPhone 4S, I replaced the pentalobe screws on the bottom of the phone with phillips screws from the iFixit liberation kit.
I'm having two problems:
1) The screws are not flush with the bottom edge of the phone and won't go in any farther. They are almost all the way in, but not quite.
2) The screws won't come out. I can turn them clockwise or counterclockwise, but they don't go in or out. They just spin in place.
Neither of these is a big problem right now, though I'd prefer that the screws go all the way in and sit flush. My concern is that I can't open up the phone if I need to make another repair in the future.
Any idea what is going on here? Is there anything I can do about it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 12
添加一条评论
4个答案
最有帮助的答案
Sounds like the screws are stripped. You may want to try some of these tricks to remove them: What are your tips/tricks for removing or extracting stripped screws?
这个答案有帮助吗?
得分 2
添加一条评论
If they are just spinning just try sliding the back cover up
这个答案有帮助吗?
得分 2
2条评论:
this actually fixed the problem thank you.
完成的
What dobyou mean slide the back cover up
完成的
添加一条评论
I need help with that my creen went all black it son but just the screen and it makes noices when i plug in the charger and idk what to do, were do you think i should put it???
这个答案有帮助吗?
得分 2
2条评论:
and it just wont work:(
完成的
What do you mean?
完成的
添加一条评论
With cheaper (vendor-supplied) drivers, the shaft sometimes loosens. It looks and feels like the screw is turning, because the handle is turning. In fact, it is only the handle that is turning; the shaft (and the screw) remain stationary. Strange, but it happens. Solution: try another screw-driver.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
sbroberts 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 21
总计 36,588
