跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy 平板电脑系列的第三代产品,配有 7 英寸屏幕,于 2013 年 6 月 24 日发布。维修此设备需要用到螺丝刀和撬装工具。该设备有白色和金棕色可选,提供 8 GB、16 GB 或 32 GB 存储容量,并配有一个最高支持 64 GB 扩展的 microSD 插槽。
Why won't my tablet's screen respond to touch?
My tablet is on, but I am unable to use it because my touchscreen is not working. I tried resetting my tablet, but when I turned it back on, my screen was still not responding to touch. Why won't my tablet's screen respond to touch?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 310
73条评论
still waiting
由完成的
my tablet developed this same problem after I dropped it. I suspect something inside has come lose, or maybe broken. I found another site that recommended steps like doing a hard reset by holding the volume up and down at the same time and pressing the power button. I tried this and it gave me the option of starting normally or going into recovery mode. unfortunately my screen was still unresponsive so I suspect its the something lose or broken problem and I have to replace my tablet
由完成的
This hard reset worked for me. Holding volume button and power. Thanks. ;-)
由完成的
My tablet has just frozed on one screen can't turn it off or on can someone help please
由完成的
My surface pro 2 touch screen stopped working just don't he swipe screen so I can't get to my password and therefore don't have access to get inside the tablet. Ive done a refresh and of course restarted an dconpletely turned it off. It is completely charged. I don't know why else to do. Any suggestions?
由完成的
显示更多的68条评论
添加一条评论
16个答案
已选择的解决方案
Hey Aaron,
The problem could be as simple as an interfering screen protector. Try removing your screen protector or device case and see if the touch screen will work then.
Since you already reset your device and it didn't work, try replacing your screen. You may have a faulty screen and digitizer, which is why your device won't respond to touch.
If all else fails, replace your motherboard. This is the main component of your device that deals with all of its functions, and if you have tried all of these solutions, then your device should start working again. Check out our troubleshooting page for more information on your device's problems!
这个答案有帮助吗?
得分 42
14条评论:
but what if it does work but only some parts in the screen doesn't and what if the keyboard doesn't respond when you click on a letter
由完成的
Rubbish. That means you are losing screen functionality. Your screen may be using a large percentage of your battery. The Android OS (operating system ) on your device should not be using more than 12% of your battery. Although I realise you are unable to check. When you device has been in while place the palm of your hand on the front and back of your device, if it is not then you will Need a replacement screen but don't do this yourself as you will void the warranty
由完成的
Try this. it work for my tablet.
It it the battery head problem. use some paper to top up the battery connector cover back. it will compress the head. it is fix. for screen on and off.
2) screen not function - try this. add some paper to the centre on the motherboard. it will compress when u cover it back. it work for me. tq.
hope this will help you guys.
由完成的
My screen was broken so I installed a new screen. The screen does come on but it will not allow me to unlock the tablet. The screen seems totally unresponsive. I was able to take my finger across the screen and get to another screen but not the one that has my apps. I thought it might be my screen saver because it had bubbles under it, so I took if off and still cannot get to my home screen or unlock the tablet. I have a Dragon Touch A1X ten inch tablet. It worked great until the screen was broken and I had to replace it.
由完成的
Try holding down the home button
由完成的
显示更多的9条评论
添加一条评论
i had this same problem on 2 different tab s2's here is what i figured out......
the trick i found out is to not put your tablet in power save mode, my buddy had his in power save mode and the touch would not be responsive after we locked the screen, so we exchanged it (of course we didnt know this was the issue at 1st) and got a new one and did the same thing, initially reading on here and trying all these other "Solutions" i thought it was apps he was installing.. deleted those and nothing...so i see his tablet is in Power Save Mode and i turn it off...and WALA!!!! it worked, no problems with it now it works fine....i mean we have a volume down key issue but its not too too big of a deal... but i really hope this helps you guys, i was really annoyed with customer service, they didnt help at all, they just pointed me to a sevice technition in my area, and they will charge you, i forwarded this info to thier head of quality control with my info hopefully they can get back to me to help the later versions with this problem, its a very nice and amazing tablet when its working :)
这个答案有帮助吗?
得分 23
33条评论:
how do you turn off the power save mode when you can't get the screen to respond and it's locked it won't even accept the swipe to open?
由完成的
"To force reboot your device, press and hold the Volume down and Power/Lock keys on the device for 10-20 seconds. This performs a simulated battery disconnect." This worked for me today after turning on the power save mode last night. Everything is back to normal now.
由完成的
I did this on my husband's tablet -- turned off the Power Save Mode, rebooted and the touchscreen started working again. Thanks for the advice!! He is very happy again!!!
由完成的
Your great man... Your answer Help me... Thanks a lot
由完成的
Thank you, thank you, thank you! Pressing and holding volume down and Power keys worked just brilliantly. I wonder why this happened to my tabS now, after more than a year working on power saving mode and never having a slightest problem. I also noticed that when the screen was non responsive the tablet would not charge.
由完成的
显示更多的28条评论
添加一条评论
Wow what rude responses for this question. If the touch does not work after the reset you tried and there is not a screen protector on it, I would replace the screen. The screen on the Galaxy Tab 3 is not a difficult one to swap out. If you need any help doing it, there are guides on this site for you. Hope you find the fix.
这个答案有帮助吗?
得分 10
3条评论:
brilliant.thanks heaps.worked straight away.now i think i will disable the power saving mode.to avoid a repeat.as suggested in this forum.i love my samsung tablet.
由完成的
So you replaced non cracked screen and it works again ?
My screen was broken but it worked. I place a new one and it work couple of months but now it doesn't. I think I will try with another replacement.
由完成的
The whole screen or digitized glass only?
由完成的
添加一条评论
if your android system is not responding and stuck in the same page even if u are trying to make it on/off and still staying in that page just press on the power button hardly at least for 10 sec and ur android system will shut down and just switch it on
这个答案有帮助吗?
得分 8
10条评论:
thank you! this worked
由完成的
still not function
由完成的
whoops,i posted my reply to above answer.lol. but thanks so much for your too easy fix to my annoying freeze problem.and next will be to disable power saving mode to stop recurrance.as it never used to do this,but lately is happening alot. thanks again/
由完成的
Yeah my rca tablet won't let me swipe to get in idk what to do
由完成的
Can't even get in
由完成的
显示更多的5条评论
添加一条评论
We have an Asus tablet that first had intermittent touchscreen problems such as non responsive areas on the screen and ghost touches. All the factory resets and software updates did not help at all. We bought and installed the new digitizer screen - no change.
Cause:
bad contact of the digitizer ribbon cables due to the loose latches.
Advise that finally helped:
cut a piece of film (like the film used to protect the screen) to the size of the digitizer cable and insert it on top of the ribbon cable into the same slot.
The problem seems to be common across all manufacturers.
这个答案有帮助吗?
得分 5
4条评论:
Say this in a different way I don't follow the advice. I have replaced my digitizer and then whole LCD and still no touch response. The film holds the ribbon cable into its receptacle?
由完成的
You are my favorite person on the planet right now! Thank you!!! This fixed my kids tablet and he's so excited he's running in circles yelling!!! Thank you!
由完成的
What is all that. Can u help me. Please
由完成的
please my tablet cannot swipe please i need help
由完成的
添加一条评论
Same thing happened to me here is my solution. 1. Do a force rest by pressing both volume buttons and lock button. After rest your screen will still 'lock up' again if you lock your screen so be careful. 2. Do a update of your tablet. This fixed my problem. However I did not drop my tablet. It was a operating error.
这个答案有帮助吗?
得分 3
6条评论:
I tried everything and my Samsung Galaxy tab 3 still won't respond to the touch plz help
由完成的
Ok i am trying to do a hard reset on my dragonforce tablet i hold power button and volume button simultaneous and then this pic comes up
由完成的
I had the same problem and the hard reset fixed the touch screen. Thanks for the solution. :)
由完成的
DickDickDickDickDick
由完成的
I don't want to reset it
由完成的
显示更多的1条评论
添加一条评论
My tablet would not respond to me touching the screen so i searched up ways and none of them worked so i kept pressing buttons and figured out that if i held down the home button it fixed it.
这个答案有帮助吗?
得分 2
2条评论:
See I have the next book tablet so I don’t have a home button so for there how can I get it to respond to me
由完成的
For how long did you wait for it to work? and did you have to restart it after or did it just worked.
由完成的
添加一条评论
I just let the battery run out and when I recharged it, it was working again :-D. My little daughter is made up and so am I as this is the second one she's had and I wasnt going to buy another until Christmas ha....
这个答案有帮助吗?
得分 1
2条评论:
Thank you for advice though because it was the touch screen that would not work so I will turn battery saver mode off but dont no how? CAN ANYONE PLEASE HELP
由完成的
It should be in your settings.
由完成的
添加一条评论
In my case, it was faulty microSD reader inside the phone. Try unplugging the microSD.
这个答案有帮助吗?
得分 1
添加一条评论
My touch screen still does not work but I can use an external mouse and keyboard until I can fix it and I had to push the home button several times to get past the swipe screen. Holding the home button down DID NOT work for me. I had to push it several times up to about 6 or 8 times and the screen pops past the swipe screen and comes to the normal main screen every time. I have a Samsung tablet. That's what I discovered.
这个答案有帮助吗?
得分 1
1条评论:
My galaxy tab sm t705 motion control doesnt work
由完成的
添加一条评论
I have Samsung tab 3. 10.1 i just replaced the lcd motherboard ribbon and my touchscreen wont work. I try steps above and nothing seems to work. Can someone please help?
这个答案有帮助吗?
得分 0
1条评论:
Hi!!! I have prestigio 3101...its new but touchscreen doesnt responde..2or 3 numbers and nothing else..than again 2 or 3..what I can do?
由完成的
添加一条评论
I have a problem too. My lock screen isn't working. It just displays black. I can't access my notification panel and it is struck at same time and battery percentage. Rest of all apps are working properly. The only problem is with lockscreen and status bar. I don't know what to do now. I have tried to restart,but it doesn't. Powermode is also off. Need some solution!
这个答案有帮助吗?
得分 0
添加一条评论
I have already posted my solution to the blank screen and buttons not working, I removed my A6 from the ,magnetic case and it immediately work as it should, as an experiment I put it back in the case and everything went black, removed it from the case and it worked OK again, I had originally tried to reboot it which did work but only to restart it, touch screen did not work along with home button etc. Why it should act up now after having been in the case for a long time s a mystery
这个答案有帮助吗?
得分 0
添加一条评论
My son got a kids tablet it is kuio for Christmas and it was working good yesterday till I got it off the charger and it was still on and now it won't let me to touch anything on my screen
这个答案有帮助吗?
得分 0
添加一条评论
I am having a problem with my Galaxy Tab A8. The touch screen just stopped working. I can't get past the lock screen. It has never been dropped and has no cracks whatsoever. Please help😔
这个答案有帮助吗?
得分 0
添加一条评论
my samsung galaxy tab pen wont turn on even after hard reset, how this happened was my little brother threw my tablet then the screen fell off. I putted it back then it wont turn on (reminder the battery was at 70%.) I tried to restart but it wont turn on all it gave was a little vibrate, then i tried hard reseting it it just gave vibrates but the screen didnt even turn on i really need answers because i need this for school please help
这个答案有帮助吗?
得分 0
1条评论:
Same problem I have 😭😭😭😔😔😔
由完成的
添加一条评论
添加你的答案
Aaron Lee 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 49
过去 30 天: 278
总计 571,062
