跳转到主内容
Why doesn't the keyboard dim in bright light?
Well, i bought a Brand-New MacBook Pro (mid 2010), and i'm having some technical difficulties with the keyboard backlighting.
If I am not mistaken, When the Ambient light sensor "sees" that there is enough light to see the keys on the keyboard, it should turn off keyboard backlighting and if there is not enough light, then naturally, the keyboard would brighten.
My problem is that the keyboard dims when there is not enough light to see the keys, but brightens when there is obviously enough light.
Whats wrong? Did I screw it up? How do I fix It?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
it won't let you manually adjust if it's in high light. that's what irks me.
完成的
添加一条评论
4个答案
最有帮助的答案
Sounds to me like the wires are reversed. Take it back to Apple for warranty repair.
这个答案有帮助吗?
得分 2
1条评论:
+ It's under warranty and they'll correct it.
完成的
添加一条评论
I just bought a new 17" MBP, and I'm having the exact same problem. The old ones had a sensor under the speaker grill and the keyboard would brighten when you put your hands over it. The new ones have a sensor at the top by the iSight camera, and it behaves in the opposite manner. :( I'm calling Apple to find out WTF is up.
这个答案有帮助吗?
得分 1
3条评论:
Just got off the phone with Apple. The guy on the phone didn't even know they moved the sensor and argued with me before talking to a superior to confirm what I told him. He said they've had no other complaints about my keyboard lighting situation, but they are going to keep my case number active. He suggested waiting a while to see if this is a common issue. I'm heading to the Apple store now to see if their display models act this way.
完成的
Just got back from the Apple store. Their machines work as expected (keyboard light is off without any ability to adjust the light until you cover the sensor with your finger to simulate a dark environment).
So, I took my MBP over to a VERY bright light and BOOM, the keyboard light went off. So, I'm hoping that it's just my sensor that is very under-sensetive to the light. I'm going to find out though, because I'm taking mine into their store tomorrow.
Hope this helps.
完成的
Check out this thread for much more info on this problem: http://discussions.apple.com/thread.jspa...
完成的
添加一条评论
One workaround is to use the F5 and F6 keys to manually adjust the brightness.
这个答案有帮助吗?
得分 0
添加一条评论
One workaround would be the App 'Lab Tick' (found in the Apple App store), which allows you to control the brightness of the keys.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Danny Arenales 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 5,630
