跳转到主内容
Model A1347 with 2.4 or 2.66 GHz Core 2 Duo Processor.
76 个问题 查看全部
问题已关闭
Can I use this memory to upgrade the MacMini?
Here is the link to the memory I want to buy:
http://www.newegg.com/Product/Product.as...
It looks like it should work but I am concerned that it won't because it has a higher speed rating. Shouldn't it just run at the lower speed rating that the machine is capable of?
MacMini4,1 currently 4GB, 2.4GHz Running Mavericks and up to date EFI.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Your box supports 1066 MHz PC3-8500 DDR3 SO-DIMMs. So theoretically it would work... but the brand name is unknown, e.g. not top tier. Crucial, Kingston, PNY.
Sometimes it 's the tightwad that ends up spending the most $... for ~20$ I'd go top tier.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
The mid-2010 Mac mini officially supports up to 8GB of DDR3-1066 RAM; but it does run 16GB DDR3-1066's -- it doesn't, however, support higher clock speed modules.
As far as G.Skill as a brand is concerned: they aren't "unknown". They have a solid reputation for performance products. Sure they don't have in-house memory IC's (ie: Crucial/Micron, Kingston, Samsung, etc), but they are hardly considered an "unknown" brand. But I digress...
OWC offers 16GB DDR3-1066's that work in the Macmini4,1's at a $50 premium (http://eshop.macsales.com/item/Other%20W...).
My set are using SK Hynix H5TQ8G83AMR-PBC. Judging from SK Hynix's product coding convention, that "PBC" part indicates it's a DDR3-1600 @ 11-11-11 timings; however, the modules are apparently clocked as DDR3-1066 @ 7-7-7 timings.
这个答案有帮助吗?
得分 3
1条评论:
Very Knowledgeable and Helpful Thank you very much
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 6
总计 1,727
