跳转到主内容
加入维修社区 - 创建账户
The Super Nintendo Entertainment System (SNES), or simply the Super Nintendo, is a 16bit gaming console released by Nintendo in 1990. The Super Nintendo was one of the best sellers of its time and still has a large fanbase today.
My super nintendo does not load all games and only some partialy
I recently bought this snes from a garage sale and found that it didnt load games, after leaving it on for a couple hours with super mario world in (a game i know i know works from my other snes) i hit the reset button and it poped up with the nintendo logo but thats all, i tried other games and found that it would partially load mario kart (i could go through the menu but would fall off the track as soon as a race started) i then tried mario all stars with no issues at all. after trying every game in my collection, no others work on this snes but work perfectly on my other snes. please help me, this snes is in beautiful condition and i would love to see it working.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
5个答案
最有帮助的答案
You should try to clean the cartridge / game reader.
Don’t blow inside it, try to use a very fine sandpaper, to rub inside the cartridge reader.
This should do the trick to be able to read/play the games again.
If this isn't working, maybe you need to replace it or try a System cleaning kit.
这个答案有帮助吗?
得分 1
添加一条评论
Yeah, I've had this problem also. it's not the games, but the circuit board inside the SNES. It seems to happen mostly on the first SNES board from 1991. The one with 4 chips on the south part of the board, and the separate sound card that is removable on the north east part of the board. Some games work, some don't work, some have a couple shadowy red bars through the screen, and some games even work but the sprites (characters) have no detection of one another in game play itself. I have cleaned up 2 different boards of this type and replaced all the capacitors, and the 64 pin cartridge connector on both boards, and both still have these problems. I think these models just go bad. Not worth really trying to experiment on these any more. I wanted to play games on these original machines. But no luck with that. I did get a SNES 2 and that works fine. So if you see for repair or parts an ebay, just save your money and invest on one that says it works. :)
这个答案有帮助吗?
得分 0
1条评论:
If you have a SNES that doesn't work please send it to me lol seriously I keep an eye out on eBay for a cheap 2 chip board but they won't atleast 40+ you could stick it on their for 0 dollars
完成的
添加一条评论
Had same problem. Probably cpu or ppu chips. I replaced my cpu because a lot of my games wouldn’t load or the sprites and graphics were missing. I had new life but certain games were still not working properly. I have 1 more replacement cpu to try, if that doesn’t work I’ll have to move on to the ppu’s. I am very hopeful though. My snes is also in mint condition which tells u how crappy the first version was.
这个答案有帮助吗?
得分 0
添加一条评论
It's more than likely the one or more of the CPU, PPU1, PPU2 chips I have had my oem power supply adapter go bad causing a wavey line issue the best thing to do first is #1 clean the cartridge slot with a tooth brush and alcohol letting it dry good first before turning it on #2 buy a burn in cartridge it will check the internal chips giving you a place to start I hope this helps 😊
这个答案有帮助吗?
得分 0
添加一条评论
I recently had the exact same issue with an SNES I bought at a flea market. It was working perfectly for months. I was playing Drakkhen when suddenly the audio got an unbearable annoying loud whine. I reset the game, but the problem persisted. I then tested other games and most would not load at all. Some, like Donkey Kong Country would load a credit or title screen and freeze. Others, like Tetris 2 and Kirby Super Star play fine.
I talked to a game store about it and they said it sounded like a blown capacitor. I was using a third-party power supply which they suspected as the cause. This explanation makes sense because all the games that are working are essentially 8bit ports which perhaps can run ok with fewer capacitors. The flea market vendor I purchased it from agreed to exchange it for a working SNES, so I didn't pursue it any further.
Sadly, now I find that most games are difficult to load on this new SNES, but it seems like the pins may just be dirty or loose. This is clearly a different issue now, as I can eventually get all my games to work by repeatedly ejecting, reloading, and wiggling them.
I suggest looking into testing and replacing a bad capacitor.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Adam 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 30
过去 30 天: 144
总计 17,398
