跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Getting help with unreconized part
Hello,
After replacing LCD screen I've noticed a tiny part that pop-out from the phone but I don't know where it's belong.
I'm assume that it's related to the proximity sensor cause since the LCD replacement it's not working properly.
Please tell me where to put that part.
Thanks.
http://s30.postimg.org/8ex897pzl/IMG_392...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Does anyone knows how those it called? I've lost it and I'm trying to find it on eBay.
完成的
添加一条评论
2个答案
最有帮助的答案
The part is not the actual proximity sensor itself, it is simply a part for aligning it.
You can go to the repair guide step by clicking here.
It can easily fall out after you remove the earpiece.
I hope this helps!
这个答案有帮助吗?
得分 1
1条评论:
Thanks!
Do you know how those it called? I've lost it and I'm trying to find it on eBay.
完成的
添加一条评论
That part goes in just to the right of the front facing camera. When you put the camera shield on the top left screw should go through that little hole
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Maor 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 4
总计 78
