跳转到主内容
The HTC One X is the first HTC phone to be equipped with a quad-core processor, released in April 2012.
My HTC One X screen has just gone blank...
My HTC One X was working perfectly fine but then suddenly the screen went black. I tried connecting it to the charger but the red charging light wouldn't come on. I also tried ringing the phone but nothing happened. I tried holding the power button for about 15 seconds, still no response. The final thing I tried was to connect it to the computer to see if the computer would detect the device however the computer didn't. I don't know what else to do, HELP?!?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 13
8条评论
keep holding the power button and the volume up it worked for me
完成的
Thank you , Yasa. A great fix. Did the trick !
完成的
@Yara Mansour I love you rn I you are my life tbh
完成的
This totally saved me! Thanks!
完成的
hey guys it worked forme too. since yest night ithad this issue suddenly turned blank. when called said switchoff. but could get whatsapp call, but could not attend. alarm was ringing but could not slide to off. but this trick worked thks very much
完成的
显示更多的3条评论
添加一条评论
6个答案
最有帮助的答案
Mine blanked too! This twist thing (below) actually worked:
http://www.htconeforum.com/forum/htc-one...
这个答案有帮助吗?
得分 1
2条评论:
Great!! Twisting got my black screen problem solved! Thank you for sharing :)
完成的
i have the same problem , Adinda Adinda how solved black screen problem
完成的
添加一条评论
It seems your phone died for broken motherboard or battery, you need to send for professional check.
这个答案有帮助吗?
得分 0
1条评论:
Are the local phone repair shops fine? And do you know how much they will charge to repair it.
完成的
添加一条评论
You have what's know as the black screen problem, ( I have too) there is a fix but it involves taking the phone apart and putting a bit of paper between a ribbon cable bend. I'm looking for the fix again myself. In the meantime I bought a new phone LG G2, (good phone recommended) I'll post back here once I find the fix, but it's not for noobs.
Found it: http://www.htconeforum.com/forum/htc-one...
这个答案有帮助吗?
得分 0
添加一条评论
hameed_kakar2003@yahoo.com
这个答案有帮助吗?
得分 0
添加一条评论
mine was taken back to china.apparently not even flashing wold help and no one knew wat the !&&* was going on.am still waiting for my phone
这个答案有帮助吗?
得分 0
添加一条评论
How to fix htc one x overheating? Touchscreen sutting down automaticly
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Haroon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 42
总计 42,817
