跳转到主内容
Toshiba Satellite M55-S1001 (Celeron M 1.6 GHz, 256 MB RAM, 60 GB HDD)
Why are these HDD connectors not the same?
Here is the computer connector and the hard drive. Why are they different?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Your Toshiba unit uses a PATA interface for it's hard drive. Sadly, the drive you have here is a SATA based hard drive which is a newer standard.
These drives are not interchangeable as you have discovered these use very different connectors.
这个答案有帮助吗?
得分 3
1条评论:
Thank you!!!
完成的
添加一条评论
添加你的答案
Matthew Halbert 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 195
