跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
Screen brightness only partly working with slider
Hello,
I replaced my iPhone5 battery and during that process something went wrong. My LCD screen wouldn't turn on anymore and it is probably completely broken. So I bought a new LCD/digitizer. I fully replaced it and my iPhone is working again.
However my screen is very dim. The backlight is working up to around 35% of the brightness slider. I can dim my screen with the slider to 0% (and make it brighter again), however above around 35% of the slider it makers no difference. Although the slider is at 80% or 100%, the LCD is still very dim like the slider is at 35%.
Someone has a suggestion on how to fix this? I already bought another LCD/digitizer but it had the same problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
I would troubleshoot like this:
1.) Rule out software--hard reset, then restore
2.) Rule out peripherals (sounds like you've done this) known good LCD screen/put board in a known good housing
3.) Send board out to someone like me but ideally local for backlight repair on the motherboard--replace filters, backlight ic, backlight coil
good luck!
jessa
这个答案有帮助吗?
得分 0
1条评论:
Thank you for the reply jessa.
1) It's not a software problem, because I already did a full (hard) reset without improvements.
2) I will buy another LCD screen from an other store. (bought two from the same store, both same problem)
3) When above steps won't work I might go for a backlight repair and see if that solves the problem.
完成的
添加一条评论
how to resolved iphone 5 brightness light . and network problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Frank 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 751
