跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
How can I reattach the bezel screen clips (they broke off)?
The bezel clips that attack the front assembly to the rear casing broke off. Should I use a little bit of gorilla glue or is there a little trick to putting those clips back onto the bezel? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
Now is it the full frame with the clips that came off the screen?
If so they yea a little bit of gorilla glue will do the trick just let the glue cure first as that glue expands and you don't want it gluing to the inside of the phone cause it's strong stuff..
这个答案有帮助吗?
得分 0
1条评论:
No, just the clips themselves.
完成的
添加一条评论
I would buy a new bezal then because it will cause problems it's very inexpensive.
Glueing the clips on will most likely break off when trying to take screen out again
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
omid 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 320
