跳转到主内容
The Samsung Galaxy S 4G is an Android 2.2-powered smartphone with a 4-inch AMOLED touchscreen display and 1 GHz processor.
62 个问题 查看全部
Samsung Galaxy S 4G Restarting Loop
Hello,
My Samsung Galaxy S 4G is stuck in a restarting loop. The battery isn't the problem, I haven't gotten into contact with water damage. This happened after I turned it off to charge my phone once charged I tried turning it on. It only goes to the Samsung screen shuts off again and returns, and has been in a constant loop for hours. I have done research showing the power button could be the problem... is this true and how much will it cost to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Take the battery out for a while, then try to restart the phone.
If still, should try to check if it's software problem. Root the phone or factory set, but you may lost the data in the phone.
If all failed, you should doubt if it's the problem of motherboard. And at that time, you have to send for professional check and repair.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alexis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 165
