跳转到主内容
The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
222 个问题 查看全部
Nexus 5 back cover lose after opening
I opened my nexus 5 to make a repair, but the back cover did not close very well. There are a few points where I suppose the plastic clips were damaged and there is a clear separation between the back cover and the phone. Is there some sort of glue I could use to secure the cover better, but still leave it able to be opened again in the future? Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
Either choose double-sided adhesive or replace a new back cover.
这个答案有帮助吗?
得分 0
3条评论:
Thanks. Do you have a double-sided adhesive you would recommend for use with phones? I don't think the issue is bad enough to warrant buying a new back cover. It's really only one, maybe two clips that are damaged.
完成的
Only mentioned that the adhesive used on phone called 3M adhesive like that http://www.witrigs.com/oem-back-supporti... You can pick up and stick it, but the adhesive is a little strong.
完成的
Thanks for the suggestion. I decided to give this a try. http://www.amazon.com/gp/product/B00BXYW...
完成的
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,514
