跳转到主内容
激光传感器 4按键 轨迹球
scroll ball only works in one direction
I have a mighty mouse and the scroll ball only works in the right to left direction. In older mechanical mice, every so often you needed to take the ball out and clean the wheels that the ball touched on the inside. How can I safely take the cover off the mighty mouse and check to see if the inside needs cleaning?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
最有帮助的答案
There's another answers topic on this subject here.
这个答案有帮助吗?
得分 1
添加一条评论
First, try a lint-free cloth with a little isopropyl alcohol or similar on it and rub the ball with it in all directions for a while. Works nearly every time. When my mouse acts up i'm sometimes a bit sloppy and just rub it over my trousers which works just as well.
这个答案有帮助吗?
得分 0
添加一条评论
Eventually even the trouser trick wont work. Follow these images to see what you need to do. Its not that hard, but you need a little glue when you are putting it back together.
http://www.applematters.com/index.php/ga...
这个答案有帮助吗?
得分 0
添加一条评论
use a vac over the ball
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Paul Watson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 7,056
