跳转到主内容
The HP Deskjet F4480 Printer/Copier/Scanner. This printer was intended for home or small office use.
Why are no words printing on the paper?
when I print it goes through the rollers but comes out blank
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hi,
Try to print test page:
Press and hold the Power ON button and the Cancel button (x).
If the printer again print blank page, then 90% you have problem with the head.
You can try to clean it or to buy new one.
Regards.
这个答案有帮助吗?
得分 2
添加一条评论
Hi, You may be out of black ink. I don't know if it's HP thing or Windows thing but black regular documents are forced to be printed with black ink, when it's out, the printer gives back blank paper. Try removing black ink cartridge only, printer will then switch to mix it's colours to make black and then try. Also try changing text colour while printing to see if it's print. You can also download HP software and print test page. If it'll work, it means you're out of black ink
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ann 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 782
