跳转到主内容
Also known as the GS70 Stealth, this 17" gaming laptop was released in summer 2013 by Micro-Star International. Identified by the model number MS-1772.
20 个问题 查看全部
Can we remplace mate screen for glossy screen?
hello i got a question can i remplace my mate screen for mi msi gt70 stealth for a glossy screen? and if i can how i can do it? thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
最有帮助的答案
Looking for the same thing, I just found a website:
https://www.laptopscreen.com/English/mod...
(I haven't bought anything from them yet, don't know if they are accountable)
这个答案有帮助吗?
得分 1
1条评论:
I have owned two generations of GS70 - 2013 version and latest 2015 version. They have different displays.
I've found and successfully replaced both screens with glossy panels.
完成的
添加一条评论
I don't know about that but only easiest way around is to apply a crystal clear screen protector on it. It would look more glossy but not be compared to those Gorilla glass screen.
这个答案有帮助吗?
得分 0
添加一条评论
Yes GS70 screen panels has glossy versions. But note that there are several generations of GS70 and they uses totally different display connection types (parallel interface LVDS, and new serial interface eDP).
So the best way is to pull out the stock display, write down the model number, then start to search online for the corresponding glossy version.
I found the easiest and most cost effective way is simply applying a glossy screen protector. The appearance is no difference from having a real glossy panel. You need to be very careful when applying the film to not having bubbles.
http://www.amazon.com/gp/product/B00D84G...
I have tried both ways, and I will stick with the 'glossy screen protector' method.
Because the glossy panel's surface is very fragile, you need to apply a glossy protector to it anyway.
这个答案有帮助吗?
得分 0
添加一条评论
Before and after applying the 17.3" COOSKIN glossy protector. The result is STUNNING :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jorgerendon91 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,745
