跳转到主内容
加入维修社区 - 创建账户
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
iPhone 5 Screen won't rotate
Not sure if anyone would know how to fix this, but I have an iPhone 5 (GSM) where the screen won't rotate.
The orientation is not locked. I believe the device is on iOS 7.1 (updated via. iTunes) and can't get it to work for the life of me. I've tried a new LCD/Digitizer using an extender cable, but still won't work. I have a feeling that it's in the logic board somewhere? Is there any way that this can be fixed? Is it possible that it's a software problem?
Any help would be greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
添加一条评论
13个答案
最有帮助的答案
In most cases, people who have the rotation issue just need to unlock the rotation lock. If you are not sure how to do this, I have written up a tutorial here.
Since you said that you have unlocked it and it does not work, it just might be a faulty sensor. However, it seems that you have opened up the iPhone, double check that you are putting the screws in the right places as the magnetic screws can cause an interference if placed in the wrong spot!
这个答案有帮助吗?
得分 6
添加一条评论
The gyroscope is faulty and yes this is a board fault
这个答案有帮助吗?
得分 5
1条评论:
Thanks all for your response. Do you have any instructions or images of where/how the gyroscope can be fixed?
完成的
添加一条评论
just unlock phone - on main screen swipe bottom to top (like when you open flashlight) click on fifth icon at top - if highlighted it's locked - so click to unlock
这个答案有帮助吗?
得分 5
5条评论:
Thank you Cathy. You're the only one that helped me unlock the 5th icon on top, the orientation works now!
完成的
Did not know about swiping bottom to top--it fixed orientation problem which occurred after I upgraded the system. Much thanks!
完成的
Thanks, didn't know that either!
完成的
Indeed just helped me now, after new upgrade of IOS, it was no longer rotating, now sorted
完成的
This was brilliant. I had been trying to fix this since last night and read your directions and now life is back to normal. Thank you.
完成的
添加一条评论
Download an app called "sensor monitor" to check gyro/accelerometer value, if check fails, restore the software, if it still fails then it is a hardware issue.
这个答案有帮助吗?
得分 4
2条评论:
Thanks. I'll give that a try today. Any chance that you may have a repair tutorial or any documentation on how to fix the gyro/accelerometer?
完成的
Logic board repair is very complex and require a lot of skill. First you have to remove the EMI shield, then diagnose the problem, then replace faulty components.
完成的
添加一条评论
Exact same problem. Occurred when I replaced the battery using the ifixit kit. Apparently I've broken the phone. DO NOT ATTEMPT A BATTERY REPLACEMENT ON YOUR OWN. Take it to a store where they guarantee the work and pay them to do it. It isn't worth trashing a $400 phone to save $50.
这个答案有帮助吗?
得分 4
5条评论:
UPDATE: OK folks, I screwed up. When the battery was replaced, I failed to keep track of each individual screw removed from the square-ish RFI shield over the cable connectors. The 4 screws have 3 different lengths, and the differences are indistinguishable to the unaided eye. This is covered (briefly) in the video how-to guide, but in greater detail in the online step-by-step guide.
Failure to put the correct screws back in the correct holes can (at best) disable the sensors. At worst, you can wreck the logic board.
If all functions other than the sensors seem to be working fine, and you've just replaced the battery, then here is what to do:
Get a micrometer. Re-open the phone and remove the RFI shield over the 3 connectors at the top of the phone. Using the micrometer, measure all 4 screw lengths. You will need good lighting, fine tweezers, and even finer motor skills. You may also find a magnifying glass stand helpful. More in next comment
完成的
THEN: using the step by step online guide, insert the two shorter screws in the appropriate holes and snug them down. These have different lengths and are not interchangable!
Next, use the magnetic tipped screwdriver to try to distinguish which of two 1.7 mm screws is more magnetic. Put it in the correct hole. Ditto with the other 1.7 mm screw.
Before connecting the home button cable, power up the phone temporarily and check the sensors are working. If not, then power down, swap the two 1.7 mm screws, and try again. This should fix the problem.
Finally, power down again, reassemble, and enjoy the relief of recovering from a scary experience!
完成的
Thank you Tom. This was the only helpful post I could find! I replaced my battery and used a scanditech kit. This step was not clearly defined about the different screw sizes properly. I reorganized the screws and voila, everything works perfectly.
完成的
Thank you Tom. This was really the only helpful post I found!
I guess the problem with the gyroscope and compass is the magnetic field of the screws. Because they need to have their own magnetic field, they just work with the non magnetic screw in the right place :)
完成的
Solved my issue Tom. Thanks.
Found the right location of the screws by googling it.
完成的
添加一条评论
i would definitely rule out software first, but yes, there is an accelerometer chip that can be replaced on the logic board. there are also a couple of very tiny filters that control the screen rotation function that are very very close to the edge of the logic board---have you ever removed the battery in this phone? could be pry damage if so.
but yes, this can probably be solved with some logic board work.
jessa
这个答案有帮助吗?
得分 2
添加一条评论
I have the same. Water damage.
remove EMI shield and gently clean with alcohol and toothbrush.Oxidize parts
Good luck Rene van der Beek
这个答案有帮助吗?
得分 0
添加一条评论
Mine has been dropped a couple of times could this be problem???
这个答案有帮助吗?
得分 0
添加一条评论
I have the same problem. My screen doesn't rotate and the sensor monitor says "unknown"! What is that mean. Thanks
这个答案有帮助吗?
得分 0
添加一条评论
i have i phone 5s , while playing videos the screen is not rotating, this problem from last 3 months i dont know what to do ,warrenty is completed in 3-dec-2015 please suggest me
这个答案有帮助吗?
得分 0
1条评论:
compass is not working
完成的
添加一条评论
My roation is not working am using iphone 5s
If I don't repair it they damage my board?
这个答案有帮助吗?
得分 0
添加一条评论
I have this same problem. My rotation doesn't work after a while. But I can fix it by restarting my iPhone..
I'm jailbroken though so unsure if it's a tweak making it malfunction overtime.. no idea what causes it to get stuck honestly..
这个答案有帮助吗?
得分 0
添加一条评论
i having same problem .i already changed motion ic it steel not working .plz help me.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sam 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 39
总计 49,036
