跳转到主内容
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
Fan issue when replacing HDD
I have read here & on other sites that there is an issue if you replace the HDD with the fan. I see another site sells an adapter for this. There are also software hacks that can help remedy the issue. Is there ever an instance where it will not be an issue? Or, if I replace the HDD will I encounter fan issue regardless?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Lets see if we can get the facts straight here:
Apple has had a temperature sensor on their Hard Drives for quite some time. Over the course of the years Apple has migrated this sensor from a stuck on unit on the drive, to one that is based within the drive its self.
The Mid '11 models are the first models that used the internal temperature sensor. Apple contracted the HD manufactures to use special firmware on their drives so this sensor was accessed by the systems heat management services which controls the speed and running of many different fans within the system.
So what happened here is many people encountered issues when the fans would ramp up to full speed as the replacement hard drive people had used did not have the needed sensor and/or firmware to communicate to the heat management services so the system went into fail mode putting all of the fans into high. Of course this was not good as the fans were not designed to stay at this high RPM for long nor was it pleasant to hear.
Some people tried a software hack to trick the heat management system leveraging the SMART system heat sensor on the newer drives. But this came with a cost as this required a hardware IRQ request stealing a bit of system performance depending on how often it was polled. In addition it was slow in reacting if the polling was not to often. If you didn't have a drive that had a SMART thermal sensor you could manually set the fans to a set speed. But that too was not to good as you are now using a fixed amount of cooling so the drive or system could still overheat.
A better solution was via a hardware hack basically putting back the external sensor on the Hard Drive and splicing into the drive cable the sensor. This was the better solution for quite a while. OWC still offers this part (we bought a good 50 of them!)
After awhile the Hard Drive manufactures were able to put out drives to the marketplace that had the needed sensor and firmware to work with the newer iMac systems (with Apples blessing). So you can now get drives that don't require any hacks!
You will need to do your research here as there still is a lot of older drives out there that won't work. If you get a boxed drive look for the Apple logo on it you will be getting a drive that will work. In any case I strongly recommend buying from someone you can get your money back if you get the wrong one.
这个答案有帮助吗?
得分 3
3条评论:
Thanks for the level of detail in your response. I was looking at replacing my 1TB with a 2TB SSHD from Seagate. I do not see any Apple symbol on it, so thinking it does not have the "blessing," if you will. Where can one find drives such as you mention above (with the "blessing")? I may settle on the OWC solution, too, if I cannot find a reasonable fusion drive.
完成的
I was looking at the Seagate 2TB SSHD drive (ST2000DX001) I bought. It says it is fully compatible with Mac desktops w/o the need for special drivers or software. This doesn't directly answer if this is "blessed" or not, though. Let me know if there are further recommendations for ascertaining that piece of information.
完成的
If it says fully comparable with Apple Desktops you should be fine. You could also check out their web site or give them a call or email to be doubly sure the one you are planing to get is OK for your machine. Make sure you get this drives part number for your inquiry. I've put in the newer 1TB drives in a few systems without any problems!
完成的
添加一条评论
添加你的答案
AJK 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 506
