跳转到主内容
Why doesn't the backlight turn off while charging/synced?
When I plug my 5th gen iPod Nano into my USB port the backlight stays on and the screen just says Connected. Is this normal?
I figured the backlight would at least turn off at some point. :/
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
yes - it's normal that the backlight stays on
maybe it's a reminder that you should first eject it in itunes and not simply unplug it.
but maybe the "old trick" works for you - if you only want to charge it - eject it from itunes and let it stay plugged in - then should the regular backlight timer work
这个答案有帮助吗?
得分 1
1条评论:
+ Ralph
完成的
添加一条评论
添加你的答案
Ryan McFarlane 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,169
