跳转到主内容
The HTC One X is the first HTC phone to be equipped with a quad-core processor, released in April 2012.
42 个问题 查看全部
Can anyone help with backlight?
I have an HTC one x that has no backlight. I can only see screen if I hold up a bright light to it. It has had no damage to it that I know of and no parts change. Can anyone walk me thru this repair as I have never repaired one before?
Thank you in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Generally whenever I see this there are 2 possible solutions, once of which is not cool:
1) The LCD requires replacement (cross your fingers this works).
2) The motherboard in the phone has a bad fuse or something. This requires replacing the board/phone.
Is the phone under warranty? If it is, then that is likely the easiest way to get it fixed/replaced.
这个答案有帮助吗?
得分 1
添加一条评论
If you have the time and technical ability, replacing your phone's screen and digitizer may be the solution for a broken backlight. Be forewarned though, this is not an easy repair to do!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Sue Tipton 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 353
