跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2376 个问题 查看全部
iPhone cant find network after fall.
Hi, my friend smashed his iPhone and wanted me to repair it for him as I have done it multiple times before. When I removed the back cover I found out that the antenna and battery cables are ripped off, so I have replaced both of them. The battery works fine, but the phone was keeping searching for network. I thought that maybe it was the after market antenna so I replaced it with one from an working iPhone (and put the aftermarket one in it and it worked fine, so no problem here) and it was still searching, therefore I started to think its a software fault. While connected to my wifi, I have checked if the date sets automatically, tried cycling the air plane mode, then restored the network settings, then the phone, then updated to iOS 7.1 and it still keeps on searching. The phone shows IMEI and ICCID. Are there any other option other than replacing the motherboard?
UPDATE:
So I tried swapping logic board from another iPhone and it worked, so the problem is on the logic board, although I do not know if it is a software or hardware fault. But I tried disconnecting antenna on a working iPhone and it had the same issue as the damaged one. Therefore I am guessing that the problem could be the antenna connector on the logic board as the mating half of the antenna was torn away, so maybe the connector was damaged as well during the fall. But I really
This is the best picture i can take now, if anyone is still interested in solving this case i would be more than happy to take more pictures of the area
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
已选择的解决方案
This is pry damage from battery removal.
Inspect the board and you will find the knocked off component.
Find someone to replace and you'll be fine.
If you can't find local board-level help, feel free to contact me via my profile
Jessa
这个答案有帮助吗?
得分 1
4条评论:
Can you tell me what exactly has been knocked off? I don't see it.
完成的
look closer to the dock connector along the side of the board that is next to the battery. post pics of that area and we can help you.
完成的
I am not sure I understand your request, do you want a picture of the board or the dock connector? By the way I tried a logic board from another iPhone and everything worked fine.
完成的
The board nearer the dock connector socket area--adjacent to the baseband area
完成的
添加一条评论
最有帮助的答案
When you say it's searching for network, I'm assuming you mean searching for the mobile data? (The sim card)
If that's the case, it's a very common problem when doing reperations on Iphones. When you take the battery out of the phone it loses all sense of time. Simply connect the phone to Itunes or Wifi and give it a few minutes before restarting the phone.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for the response.
No, it can find any carriers so it says either searching... or no serivce. I had it connected to itunes whole day and nothing happened so I connected it to wifi and waited over night and still nothing. I had similar problem with my phone before so I used the standard procedures, wich did not help and after 4 hours it just connected and it was fine ever since.
完成的
添加一条评论
Hi there make sure the blue coil is still intact it's just to the left of were the antenna plugs in and just under the dock flex.. Make sure it's still there if it's not that's the reason for no service
这个答案有帮助吗?
得分 1
3条评论:
Did you check for the blue coil like I sayed?
完成的
Yes I did, it seems to be okay, but I do not have a magnifying glass with me right now, so I will check it later today if its not loose or anything.
完成的
You can check the coil on the picture, but it seems ok to me.
完成的
添加一条评论
May be that the sim card is damaged. Have your friend go by his carrier and ask for a new sim card.
这个答案有帮助吗?
得分 0
3条评论:
Thank you for responding, but the SIM card is ok, I tried his and mine, both of which are working fine on our iPhones.
完成的
It could be the sim card reader.
完成的
Thats what I am worried about. Still not sure though because when the slot is empty it says no SIM and when I install a SIM it statrs searching, so it recognizes when there is something in it, but I dont know for what functions exactly is the reader responsible for, therefore I am not sure whether the problem is in the reader or somewhere else.
完成的
添加一条评论
添加你的答案
buris97 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 652
