跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
299 个问题 查看全部
connecting charging port ribbon cable to circuit board
How does the charging/docking port ribbon cable secure to the circuit board the ribbon cable seems like it was glued with epoxy or somthing .not sure ..way to small for solder..it was originally attached flat to the board...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
The charging port ribbon cable comes with it's own adhesive, so it can be glued on.
You can see the link of dock connector flex cable replacement, the area with blue film is where the adhesive on.
这个答案有帮助吗?
得分 0
添加一条评论
I had to remove the motherboard to check this out the other day. It is soldered to the board. Not glued.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
greg 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 758
