跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
iPhone 4S battery indicatir not changing on iOS 7.
I have updated my iPhone 4S to the new iOS 7 and since then my battery indicator is stucked at 44%. Now regardless how much I charge or how much I use, it is showing the same lbattery level.
Although this get refreshed when I restart the iPhone and it shows the current battery level and then again stucks at the same percentage. This was working fine on iOS 6, but is showing issues after the upgrade.
I have tried to restore it, reset settings by selected Erase All Content and Settings, but still no good, it shows the same level of battery percentage at which it is since last reboot.
Any idea what to do now?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Maybe try a new battery? Otherwise, sounds like a bug in ios7. Probably nothing you can do until Apple releases an update.
这个答案有帮助吗?
得分 0
1条评论:
I tried to fix this issue by replacing the battery twice, but the issue doesn't get resolved. Moreover when ios7 was just released I updated my phone and got to know about this bug, I immediately downgraded to ios 6.1.3, and the indicator started working fine. However lateron I upgraded to ios 7.1, hoping that apple might have fixed this issue, but there's nothing good yet. Also now apple is not signing ios 6.1.3 ipsw now so I am stucked here.
完成的
添加一条评论
添加你的答案
Arjun Gupta 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 116
