跳转到主内容
The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
Problem with wifi signal level after repair (changing LCD display)
Hi,
after replacing the LCD unit of my Razr XT910, I got a problem with very low wifi signal level. Is it possible that I have damaged the wireless antenna ? The GPS is not connecting, too. However, it was not connecting before I replace the LCD. I am still in doubt where it is really positioned the wifi antenna.
Best regards,
Heron
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
With little documentation out there, and not having that specific model on me I looked at a couple of teardowns and images of the parts. There is two antenna's I can see on the mid frame (rear housing). One near the top, the other near the bottom. The larger of the two will most likely be cellular.
There is also a possible antenna on the LCD flex cable. I would generally think its a IC but from lack of traces leading to it, just can't be.
As for the GPS, antennas are usually in the controller for it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Heron Carvalho 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,248
