跳转到主内容
加入维修社区 - 创建账户
The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
Burned camera lens .
Hello
I am a medical student and i used my mobile camera to take pictures from a microscope but i think the extreme light from the microscope burnt the lenses because when I try to take pictures in low-light occasions the picture I get is red and pink.Can I fix it ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Did this happen recently or has it always acted this way in low light conditions?
完成的
添加一条评论
1个答案
最有帮助的答案
This is not an uncommon issue it would seem, several HTC 1 users have run into the same problems, HTC has officially acknowledged the problem and believe that it may be a firmware issue with the phone. This was acknowledged last year, if you can, I would see if there is a firmware update as HTC believes it is a software issue. If you cannot wait and you are still under warranty you should be able to ask for a replacement if it is in fact the issue.
Also I would try to lower the ISO levels. HTC is advising users to reduce the ISO levels to lessen the impact of the flaw, or return their handset and receive a replacement.
这个答案有帮助吗?
得分 2
2条评论:
Thank you for your response
完成的
Of course, I hope that helped
完成的
添加一条评论
添加你的答案
Demetris Fkiaras 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 20
总计 3,208
