跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
How to re-attach the "Display Data Cable"
So, a while ago my ipod stopped working, it was stuck in a loop of the startup screen. I didn't do anything for a while, but then more recently I decided to try and fix the home button so I could try and reset it. However, after taking it apart and putting it back together, I haven't been able to get it to turn back on. As far as my limited knowledge can tell, the problem is that I can't manage to re-connect the display data cable between the display and the body.
Extra: If I connect it to my Macbook, iTunes won't detect it unless I put it into recovery mode, which is why I think it is the screen. Also, it isn't the backlight because the screen isn't showing anything.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Put the display halfway closed and use a plastic tool to reach and press the cable in.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
XepherTim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 148
