跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
No service after changing screen
I have an iPhone 5 and recently I decided to changed my screen. So I took the old screen and replaced it with a new screen (camera, per-assembled). Then I put it back together. Everything was going perfectly fine, the new screen was great. Then I noticed that my phone has no service.
Things I've tried:
Resetting network settings
Hard power reset
making sure all cables are good inside
connecting to itunes
connecting to wifi
Nothing has worked, can you please help me.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Hi there Im sure the time and date are correct?
Did u remove the battery?
这个答案有帮助吗?
得分 0
3条评论:
yes I removed the battery, the date is correct too :(
完成的
Did u remove it completely? Did u pry it and leaver it off the logic board?
完成的
I mean, I just disconnected the battery cable :o
完成的
添加一条评论
添加你的答案
Jon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 248
