跳转到主内容
Repair guides and support for smartphones in the Curve line produced by BlackBerry since 2007.
69 个问题 查看全部
My trackpad and keypad are temperatmental on BlackBerry Curve 9320?
So the trackpad on my blackberry goes from not working at all to working just fine and the keypad does the same thing. The lock screen button on the top of the phone has also become hypersensitive and responds to the slightest touch, making my phone go crazy. This is the second blackberry I've had and after a couple of years, blackberrys just seem to break down; any advice?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Do you keep the Blackberry in question in your pocket, or on your belt. There's a good chance that if you routinely keep it in your pocket, a quantity of lint has crept in. You're going to need to take apart the entire case, and remove the keyboard pad. (it's a one piece jelly keypad). There aren't that many parts to the case, and there are video's on YouTube describing the tear down. Inspect for and then gently blow out the dust. Inspect the jelly keyboard also to insure that it is debris free. The trackpad issue has me a bit confounded, as the lint was a big problem with the track ball on the older model. I'm not sure about the trackpad. To disassemble the case you'll need a guitar pick or credit card to split the case, and I believe you'll need a small TORX screwdriver to remove a few screws.
这个答案有帮助吗?
得分 0
添加一条评论
can i download key pad onto the screen
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
noodlequick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 3,257
