跳转到主内容
The Samsung Galaxy Note II is a smartphone noted for its combination of a large display and software optimized for an integral self-storing stylus.
light leaking onto screen from capactive buttons
after screen/digitizer replacement on note II, there is light leak (shinng light onto) from the capacitive button onto actual screen. not the normal reports of light bleed on the capacitive buttons but onto the screen. its only coming from the right capacitive button. left is fine. If I press hard down on the screen in that area it goes away, for a bit maybe an hr, then it comes back again.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
This situation may be caused by you didn't plug the connector very well, you can have a check and have a try to re-plug.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
cbedlin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 292
