跳转到主内容
Series of 15.6" Windows laptops by Acer directed toward casual users.
7 个问题 查看全部
it will not boot but I can enter bios
I bought this laptop second hand as a dead unit, on examination I found that the I3 CPU had died, put a known good CPU in and turned on, Great, it started the POST, I get the Press f2 or f12 options, then the Acer Logo flashes up for a second or two then it hangs with the cursor in the top left of the screen, can anyone give help/advice?
PS:I can enter bios and see all devices, IE, Hard drive, CD rom and RAM, it can also see any USB devices I connect.
Things I have tried include removal of all USB devices, use of known good Ram, even removed the wireless module.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
Have you removed the CD rom and the hard drive ? and then see if it will boot farther ?
这个答案有帮助吗?
得分 0
添加一条评论
Basically probably ur boot.ini file broken or some necessary files ar mising. If you start ur pc with any boot disk like windows xp 7 8 and install new windows. I believe your problem will be fixed.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Frank Carr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 1,184
