跳转到主内容
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
201 个问题 查看全部
Phone doesnt respond to the phone lock password
Woke up this morning and found out that my Galaxy slept to well probably. It does not recognizing my phone lock password (I'm sure that it is the correct one) and i cannot enter my phone...
How does it could have happen that over night it just forgotten my password?
and what can i do to overcome it?
Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
- First way: Factory reset. Hold the Volume UP, Home and Power ON buttons together. And from the Android recovery menu select - "Wipe data / factory reset", "Yes -- delete all user data", "reboot now".
But you will lost all your data, and this is not good if you haven't a backup.
- Second way: with ADB (Android Debug Bridge). But, you can use this method only if you have USB debugging turned on from the menu before. This option is turned off by default.
- Third way: after many wrong password entries, the phone will offer you to connect with your google account. But your WiFi must be ON from before, you must be near to the network that you used before (you can't make new connection).
Regards.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Rachel meitis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 158
