跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
No backlight, new screen, after water damage
I've been "playing" with a 4s for about a year now. Friend dropped it in water and took it in for repair but they said they couldn't, so she bought a new one and gave me the old one.
I must have put that phone apart at least a dozen time. Last week I did as suggested and soaked the board in high grade isopropyl alcohol, then brushed the connectors and all. With the new screen I had bought, nothing would show up, but connecting to the computer would load in iTunes and I was able to do a restore and update to 7.1. After putting the original screen in, I was then able to see a faint image, so I knew the backlight wasn't working.
I ordered another screen from a different supplier. Replaced, and it's doing the same... no backlight, but otherwise phone is working great (can take pictures, front/back camera, sound works, wifi).
So what's the deal? I read something about a backlight coil on the board, where is this for me to verify if that is the problem? I certainly couldn't fix that. Already put a lot of money in parts trying to fix it, would be nice if this backlight issue was repairable.
Thanks for any inputs.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Yea the backlight coil has blown and a replacement should sort it.
Try finding a repair shop that has done this before and get a quote
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Sccoaire 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 78
