跳转到主内容
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 个问题 查看全部
keyboard is not responding after small water damage / repair
Yesterday, I spilled a small amount of tea on my MacBook Pro. it spilled mainly around the trackpad area and to the first row of keys, space and commend etc.
I turned it off, ejected the battery, stripped the computer, remove the logic board and removed the keyboard backlight panel and then dried the upper-case with a hair drier.
I also took out the touchpad and gave it a clean. Tragically, I tore the touchpad ribbon upon removal.
Current symptoms:
all systems work per normal except:
  • fans run non-stop
  • keyboard is totally unresponsive
  • obviously trackpad dead but new ribbon is on it's way.
what on earth happened in there? before stripping it completely after a dry, when I booted it up to test the trackpad, after about 20 seconds the volume started to go up by itself and I think random keys were being pressed.
what is my next move?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
the same thing happened to me , when a leak developed in my ceiling, dripping onto my open laptop all evening. i ended up replacing the keyboard on my late 2006 macbook pro.
rsrsparky
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Matt Rowlands 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 331
