iPhone5 home button not reponding..
Hi Admin,
Recently, i replaced my iphone5 internal speaker. But after i assembled my home button is not functioning already so i decide to replace the home button (switch) and the lighting charger assembly but still does not work. May i know whoelse encounter this problem? How u fix the issue?
1条评论
Hi Con,
Thanks for you prompt response and technical advice.
Yes, i already shorted this two prongs using screws but no response. Is it possible that i damage the mainboard when i install the internal speaker?
Isolation made:
1. I already isolate the speaker itself (damage one and new one) but the home button is not responding anymore.
2. I also replace the "lighting charger, headset jack" assembly but its the same.
3. I measure the two prongs voltage reading with respect to gnd. One has 1.72V and the other one has 0.0V.
4. The one the measure 1.72V has an open resistance while the other with 0.0V got 10kohms.
Let me know of your taught. Thanks so much.
由 charles morgan 完成的
