cracked ipad air screen
How do you fix a cracked ipad air screen without breaking your whole ipad ?
Well, first, if your iPad is still under warranty, bring it to an apple store or best buy to get it repaired
You can check your iPads warranty here
If not, it's extremely hard to do this yourself... The new iPad is even harder to open. You are better off letting a professional replace it. I recommend GeekSquad. They are located in almost every Best Buy.
If you're daring, and I DO NOT recommend doing this, but here is a YouTube video you can follow to replace the screen (digitizer): iPad Air screen replacement
I hope this helped!
If this did help, don't forget to return and mark this answer as Accepted
这个答案有帮助吗?
If you mean that the LCD is damaged, it'll be pretty hard. You will have to remove the digitizer (the glass) from the device, by carefully heating the edges of it, and using precision pry tools to remove the glass.
Then, you can order a new LCD, on the web, or from a company like eTechParts (not affiliated), and replace the LCD.
In some cases, it's impossible to not break the glass when removing it from the device, in which case you should also purchase an extra piece of glass, to replace the broken glass with.
If you are talking just about the glass, and are trying to prevent damaging the rest of the device, watch some iPad air screen repair tutorials, and take your time.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 6,433
