跳转到主内容
Released in August 2005, the Canon Speedlite 430EX replaces the 420 series. It works with E-TTL II, E-TTL, and TTL autoflash systems.
Canon Speedlight 430EX wont flash. Everything else seems to work?
First of all, excuses for my possible bad English.
The point with the flash is that everything seems to work, I can hear the condensator but the pilotlamp will not start to glow green or red. It's not working at all and the flashlite will not work. When it should be the lamp, I can imagine that at least the pilotlamp will glow up. So, can it be the condensator that is not working anymore?
I hope there is an answer for it. Tnx in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
What batteries are you using: Alkaline, Ni-MH, or Lithium? When you replace them do you replace the full set? This is important with rechargeable Ni-MH & Lithium batteries. I mark each battery with a set ID so I always Use & charge them together.
Try a fresh brand new set of Alkaline batteries (4). Does it charge up? Does the flash test button fire off the flash?
If it does then the rechargeable batteries you are using are bad and need replacing.
这个答案有帮助吗?
得分 2
1条评论:
Wow! Thanks Dan! Now, that was a quick and easy solution. I almost started to take the flash apart. I'm glad I've looked online, before making something (silly).
I have replaced batteries and it's all working again.
Regards
完成的
添加一条评论
添加你的答案
fotomeijerede 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 11
总计 3,645
