跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
问题已关闭
Power, Volume and Vibrate switch not working after Speaker replacement
Replaced iphone 5 speaker this am now power button, volume buttons and silent switch do not work. I can't find the info on the connections to check. Everything else works. Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I had went back through and checked. I had let that ribbon slip below the motherboard and it was not connected. Thanks for the help!!!
完成的
添加一条评论
1个答案
已选择的解决方案
Hi.
Power button, volume buttons and the silent switch have the same connector. Check it here:
If it´s connected properly you can check if there is any damage to cable.
Let me know what you find out :)
-Alex
这个答案有帮助吗?
得分 2
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 847
