跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
问题已关闭
Black Display, sound when connected to charger, appears in itunes,
I have already looked up whether someone had the same issues with the iphone 5 as I. And I have found similar cases but they did seem to apply on my problem.
Actually I wanted to replace my old battery. I didn't expect any troubles as I had done it before. However the phone would not work after I tried to switch it on afterwards. Nevertheless it "woke up" when I connect it to my charger and it also appears in iTunes. Strangely there is a sound every 5 seconds when it is connected.
Could one of Display cables possibly have been damaged in the opening process? What could I try to fix this problem? Does it make sense to buy a new display?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
If your display is black try a hard reset and if that doesn't work make sure the connections are fitted tight.
If still nothing it's more that likely you damaged the display
这个答案有帮助吗?
得分 1
10条评论:
thanks a lot for the quick answer. If I try a hard reset my phone stays dead and doesn't make a sound. (not connected to laptop or charger) That is worrying me a bit. I have already double checked the connections. They seem to be okay. I hope my new battery didn't fry the phone, although I doubt that. I considered having accidently unplugged a connector, but could find anything odd. Somehow each possible explantion for the problem seems to contradict itself.
完成的
Have you tryed the old battery again see if that works??
Who voted me down lol bit harsh!!!
Only trying to help
完成的
Yes I have tried the old battery again but got the same result. I really hope that there isn't a bigger issue than a broken display.
And I am sorry that I accidently rated you down- of course I wanted to rate you up. You should be up now :)
完成的
Is it normal for the phone not to make a sound or not to vibrate when swiched on or off? Because the iphone appears to be completly dead when not connected to a power source although I charged the old battery completely before the "battery exchange".
完成的
How did u charge it completely?
Does the iTunes recognize the phone when plugged into computer?
完成的
显示更多的5条评论
添加一条评论
hey im having the same issue... have u figured whats the problem?
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 676
